VPNV4-Option-C label issues
feroz syed
Level 3
Level 3
Good Morning,
i have issue with below Topology, where R16 and R1 have each other routes but not reachable, the packet get drop from directly connected PE,
Details :- XR4 (11.11.11.11/32) and R3 (8.8.8.8/32) both advertise their local PE loopback address using BGP labled protocol,
  • XR4 reddtribute learned routes (8.8.8.8/32) to OSPF 1.
  • R3 Redistribute learned routes (11.11.11.11/32) to OSPF 321.
  • XR1 and R8 form vpnv4 neighbour from Redistributed routes by XR4 & R3(Ebgp-lulti-hop).
  • XR4 has static routes towards R3 using /32 (for label support).
  • R8 redistribute vpnv4 learned routes to vrf X (address-family ipv4 vrf X
    redistribute eigrp 100) (router eigrp 100 address-family ipv4 vrf X autonomous system 100 redistribute bgp 321 metric 1000 10 255 1 1500).
  • XR1 has Ibgp neighbor to CE router, also vrf export and Import done according to isp-2 R8 router.
Verification:-
RP/0/0/CPU0:XR-1#
RP/0/0/CPU0:XR-1#
RP/0/0/CPU0:XR-1#sh mpls forwarding
Thu Nov 10 07:57:34.532 UTC
Local Outgoing Prefix Outgoing Next Hop Bytes
Label Label or ID Interface Switched
111000 44444 22.22.22.22/32 Gi0/0/0/0 192.168.13.3 0
111001 Pop 33.33.33.33/32 Gi0/0/0/0 192.168.13.3 15334
111002 44445 44.44.44.44/32 Gi0/0/0/0 192.168.13.3 520
111003 44447 55.55.55.55/32 Gi0/0/0/0 192.168.13.3 22352
111004 Pop 8.8.8.8/32 Gi0/0/0/0 192.168.13.3 18899
111005 Pop 192.168.23.0/24 Gi0/0/0/0 192.168.13.3 0
111006 Pop 192.168.34.0/24 Gi0/0/0/0 192.168.13.3 0
111007 Pop 192.168.35.0/24 Gi0/0/0/0 192.168.13.3 0
111008 Unlabelled 1.1.1.1/32[V] Gi0/0/0/1 172.16.16.1 1876
RP/0/0/CPU0:XR-1#sh mpls forwarding vrf A
Thu Nov 10 07:57:41.281 UTC
RP/0/0/CPU0:XR-1#sh bgp vpnv4 un sum
Thu Nov 10 07:58:37.488 UTC
BGP router identifier 11.11.11.11, local AS number 12345
BGP generic scan interval 60 secs
Non-stop routing is enabled
BGP table state: Active
Table ID: 0x0 RD version: 0
BGP main routing table version 8
BGP NSR Initial initsync version 7 (Reached)
BGP NSR/ISSU Sync-Group versions 0/0
BGP scan interval 60 secs
BGP is operating in STANDALONE mode.
Process RcvTblVer bRIB/RIB LabelVer ImportVer SendTblVer StandbyVer
Speaker 8 8 8 8 8 0
Neighbor Spk AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down St/PfxRcd
8.8.8.8 0 321 148 134 8 0 0 02:10:46 2
Thu Nov 10 07:58:43.677 UTC
Status codes: s suppressed, d damped, h history, * valid, > best
i - internal, r RIB-failure, S stale, N Nexthop-discard
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
Route Distinguisher: 1:2 (default for vrf A)
*> 1.1.1.1/32 172.16.16.1 0 0 100 i
*> 16.16.16.16/32 8.8.8.8 156160 0 321 ?
*> 192.168.86.0/24 8.8.8.8 0 0 321 ?
Route Distinguisher: 8:16
R8#sh mpls forwarding-table
Local Outgoing Prefix Bytes Label Outgoing Next Hop
Label Label or Tunnel Id Switched interface
800 Pop Label 7.7.7.7/32 0 Fa0/0 192.168.78.7
801 700 6.6.6.6/32 0 Fa0/0 192.168.78.7
802 702 5.5.5.5/32 0 Fa0/0 192.168.78.7
803 701 3.3.3.3/32 0 Fa0/0 192.168.78.7
804 Pop Label 192.168.37.0/24 0 Fa0/0 192.168.78.7
805 Pop Label 192.168.57.0/24 0 Fa0/0 192.168.78.7
806 Pop Label 192.168.67.0/24 0 Fa0/0 192.168.78.7
807 No Label 16.16.16.16/32[V] \
0 Fa0/1 192.168.86.16
808 No Label 192.168.86.0/24[V] \
0 aggregate/X
809 704 11.11.11.11/32 0 Fa0/0 192.168.78.7
R8#
R8#sh mpls forwarding-table vr
R8#sh mpls forwarding-table vrf X
0 aggregate/X
R8#sh ip route vrf X
Routing Table: X
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
+ - replicated route, % - next hop override
Gateway of last resort is not set
1.0.0.0/32 is subnetted, 1 subnets
B 1.1.1.1 [20/0] via 11.11.11.11, 02:09:16
16.0.0.0/32 is subnetted, 1 subnets
D 16.16.16.16 [90/156160] via 192.168.86.16, 02:17:34, FastEthernet0/1
192.168.86.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.86.0/24 is directly connected, FastEthernet0/1
L 192.168.86.8/32 is directly connected, FastEthernet0/1
R8#
R16#sh ip route
D EX 1.1.1.1 [170/2565120] via 192.168.86.8, 02:33:31, FastEthernet0/0
C 16.16.16.16 is directly connected, Loopback0
C 192.168.86.0/24 is directly connected, FastEthernet0/0
L 192.168.86.16/32 is directly connected, FastEthernet0/0
R1#sh ip route
C 1.1.1.1 is directly connected, Loopback0
B 16.16.16.16 [20/0] via 172.16.16.11, 01:37:46
172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
C 172.16.16.0/24 is directly connected, FastEthernet0/0
L 172.16.16.1/32 is directly connected, FastEthernet0/0
B 192.168.86.0/24 [20/0] via 172.16.16.11, 01:37:47
19 Replies 19
You are very welcome @Rustam Safarov and thanks for the feedback
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
if you have means could you please share the "yaml" file
Hi @feroz syed ,
Please send me an email address I could send the document to, via private message and I will send you the yaml file.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Harold Ritter
Hi @feroz syed ,
I ran my test in CML and it didn't work for me.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Hi I Know I am late but I have other solution here can you try it ??
first advertise the RR additional to PE under BGP inter-AS
and check again.
RR need to form RR-RR VPNv4 multihop eBGP
and then RR push prefix it learn to PE here PE can use RR or PE of other AS as next-hop, this depend if you config next-hop unchanged or not.
so only for try add RR ip under BGP inter-AS and see result.
