Bookmark
Subscribe
4181
Cisco Umbrella
Tree1964
Using Cisco Umbrella as firewall and attempting to play video that requires "jwplayer6" which is being blocked.   Where do I search for the Clients IP Address in Umbrella so I can tell precisely what's going on?
Thanks in advance.
Esha Goyal
In order to find block, please navigate to Reporting > Activity search > Advance search, mention the domain in the domain search box and apply the filter. You should be able to see if Umbrella is blocking a specific domain.
And then modify applied policy for the identity if changes are required with regards to domain access.
