Advise seek for choosing between ISE SNS-3615-K9 appliance model or VM
byme88
Hi everyone,
Can someone familiar with the Cisco SNS-3615-K9 Appliance version vs. the VM version?
I have a decision to make to choose between the 2.
Any suggestion with pro and con is very much appreciated.
thanks,
Byme88
Stay with appliances if you can for the following reasons:
1- both hardware and software are supported by Cisco.  This is huge.  When there are issues, you don't want to have too many chefs in the kitchen.  They are pointing fingers at each other.
I am going that issue at the moment and ISE in AWS.  you're at the mercy of different vendors.  Stay with appliances for as long as you can.
7 Replies 7
marce1000
 - Usually appliance will provide higher capacities and support more clients and NADs versus VM solution(s) , checkout : https://www.cisco.com/c/en/us/td/docs/security/ise/performance_and_scalability/b_ise_perf_and_scale.html
 M.
balaji.bandi
I prefer to go with appliance, since Cisco tweaked hardware work as expected
BB
james.king14
PROs:
Lower power consumption and no need to add space for new unit. No need to
do another cabling instance.
Same accessibility once installed.
I found that the VM works a lot better if and when there is an issue with
the system. I can access the VM core information a lot faster. I can do
backups of the entire server in a small amount of time. (SNAPshot) if a
failure happens I have redundancy of the entire server instead of just the
parts and it also allow for me to create a lab on the same Core server
without touching the prime device.
CONs: cost is about the same
Depends on systems administration structure. Access maybe denied to make
changes to core device.
Arne Bier
One thing to consider with Cisco SNS- servers, is that they are single purpose only. Once they are end of life (no more Cisco support, and ISE versions refuse to run on them), you cannot deploy any other software (like a hypervisor) on them. At that point you have an expensive brick.
PradeepSingh
In addition to all above inputs I can share experience using VMs on VMWare environment and it works without issues. Also there is flexibility to scale up and down with number of VMs. For upgrades a fresh VM can be build in parallel and replace an existing, which is an optional thing for disposal.
Marvin Rhoads
Performance-wise an equivalently provisioned VM will be the same as the hardware appliance.
ISE VM specs are pretty steep though so if your hypervisor environment is resource-constrained, it may not be a good choice to run VMs.
If you have the resources, VMs are much easier to spin up and you have more options with upgrade paths.
Some customers choose hardware appliances since the operations teams don't mix well (i.e. VMware admins not wanting or not knowing how to give ISE admins the necessary access to manage the VMs).
The downside of hardware is that it will eventually go end of sales and you also have to pay annual support costs on it. For instance, the 37xx series is expected out later this year at which point the 36xx will be end of sales. If you had VMs, you can just spin up a new one matching the specs and have a 37xx equivalent the same day. Also, the hardware obviously takes up space and power.
