07-22-2025 02:21 AM
Hi All
I want to configure MAB authentication for wireless users. The same SSID is used for 802.1X, and I would like to use MAB for specific users. Is that possible, and how can I achieve it?
07-22-2025 02:29 AM
Same SSID have both 802.1x and mab' I dont think it work
For new SSID using MAB' you can use
Local mac authc
MHM
07-22-2025 02:51 AM
yes its possible, depends on what controller you using the configuration need to look their documentation.
Good video how you can configure on ISE :
ISE deployment :
https://www.youtube.com/watch?v=PRlLDhbljIE
07-22-2025 12:30 PM
Not possible. You can do 802.1X with MAC address conditions but not both. What is the use-case? What is the access method for MAB? PSK? Something else? open?
