Docker Daemon not running - ISE 2.2 patch 4
ssambourg
I recently upgrade ISE 1.1 to ISE 2.2 patch 4.
After about 1 month of production on the new version, My 1st PAN encounters this alarm :
What's the exact job / utility of this daemon ?
I assume that restarting ISE application will solve that.
Sylvain
Ben Walters
Level 4
Level 4
The Docker daemon is related to Cisco's software container platform more info here:
https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/UCS_CVDs/flexpod_docker_deploy_design.html
Chances are you aren't utilizing it anyway but I would start with application stop ise and application start ise
Unable to get thist daemon running after restarting ise app :
2018-01-29T19:16:20.171256+01:00 srv-ise-adm-01 logger: Cannot connect to the Docker daemon. Is the docker daemon running on this host?
Attached the show status of docker app
Ben Walters
Level 4
Level 4
Run the command show application status ISE it will include the status of the docker daemon in that output, it is not a separate application.
