02-08-2019 06:31 AM
I am having a similar issue to the above bug. I am running ISE 2.3 patch 1. When I try to run the URT, i get a certificate error and it stops running. Will this effect the patch and upgrade process?
Solved! Go to Solution.
02-11-2019 03:46 AM
I was running ISE 2.4 patch 1. I could not delete a certificate out. It was causing the URT to fail. I went ahead and applied patch 5. The reason I did not contact TAC was the bug is listed as a low priority. If the bug is a low priority, it must not be causing too many real issues with operation or upgrading (that is my logic). The patch installed successfully. After the patch was complete, the suspect certificate is gone as well.
02-08-2019 08:40 AM
02-11-2019 03:46 AM
02-20-2019 09:00 AM
Adding patch 5 worked. It gave me information on where to remove the certificate, from Syslog targets, I changed cert and could proceed with the 2.6 upgrade.
