Bookmark
Subscribe
1702
Remote Agent issue with ACS 4.2
vishweswaran.k
Dear All,
We have ACS 4.2.0.124 runnning with remote agent installed on win 2003/32 bit ent server. Now we are facing issue like logs (daily backup) from ACS to the Remote Agent is not happening properly. We usually get logs around 1 MB everyday in remote agent but sometimes we are getting 1 KB continuosly untill the services to be restarted in ACS manually. Any quick help is appreciated.
ACS and Remote Agent, version and patches are same.
Thanks in advance ...
CSLogAgent is the logging service. CSAgent controls the logging service but receives logging data from appliances directly. When CSLogAgent starts, it requests its configuration from the configuration provider specified in the CSAgent.ini file. After it has received its configuration, it is ready to perform logging services. If CSLogAgent encounters problems receiving its configuration from the configuration provider, it restarts periodically until it succeeds in receiving its configuration.
When a remote agent starts, it reads its CSAgent.ini file to determine which services should be available and which appliance is its configuration provider. Then it contacts the configuration provider and requests its configuration.
Ports—By default, CSLogAgent listens to TCP port 2006 for communication with the configuration provider and on TCP port 2007 for accounting data from any permitted appliance.
What is the full version of ACS appliance? You can check this under system configuration >> appliance upgrade status.
In order to generate some logs on demand.
Go to reports and activities > administration audits > click refresh/reload few times.
From the RA server collect the below listed files.
C:\Program Files\Cisco\CiscoSecure ACS Agent\CSLogAgent\Logs
C:\Program Files\Cisco\CiscoSecure ACS Agent\CSAgent.ini
Jatin Katyal
- Do rate helpful posts -
~Jatin
9 Replies 9
Amjad Abdullah
When the remote agent not logging, what is the remote agent service status? is it running? or stopped?
Rating useful replies is more useful than saying "Thank you"
Jatin Katyal
Further to Amjad's reply, try to grab CSLOG file from the server running remote agent.
Jatin Katyal
~Jatin
we have installed this on appliance. how will i get CSLog ..?
The remote agent logs are saved in the remote agent installation directory (usually in C:\program files\Cisco\CiscoSecure ACS Agent directory). In CSLogAgent\Logs directory.
In CSLog file we are seeing pass and fail status. how to find the miscommunication between acs and remote agent..? any bug which is hitting to this version 4.2 ..?how the logs are stored in remote agent ? what protocol is been used for this communication ? pls help...
Jatin Katyal
~Jatin
Its running with 4.2.1.15 and patch is 9. In RA also same. We are getting CSLogAgent logs and not seeing any disconnection kind of errors but in Logs directory, like failed attempts, Passed authentication ... n all sometimes not logging properly. means empty notepad with 1KB. CSAgent.ini configs are proper. Any suggestion..?
Nice explanation Jatin
+5 is least thing we can provide.
Amjad
