Switch configuration required for ISE
sajid231088
Hi All,
Hope you all are doing good.
Please help me on below requirement.
We are looking for a 802.1x setup for Wired and Wireless in that we want to have 4 vlans, one vlan for wired dot1x and second vlan for wireless dot1x, third and fourth vlan would be Quarantine vlan, one for Wire and another one for Wireless.
Why we need this because our requirement is like that whenever any user connects to our networks irrespective of Wired and wireless we want to put him/her into quarantine vlan first, in quarantine vlan all posture operation should happen, once device become COMPLAINT then it should move into our corporate Wired/Wireless network or if its not COMPLAINT then it should have limited access to our network from where device will get the required things to become complaint.
I know the configuration of ISE but not sure in Switch configuration, So any one help me in complete switch configuration from start.
we have One Core SW(3560) and one Access switch(2960) for testing.
Confused in, on which switch i should create all vlans, will it be on core or access and what ports i should put in what vlan.
I wan't to have DHCP also on my core switch for all vlans.
Request you all to help me on this.
Thanks in advance.
Sajid
I'll answer your question.
1. If you need to create Layer 3 interface on the core you'll need the vlan there and as your machine will be connected on your access switch then you need there also. Between the core and access you gonna have a trunk interface with all vlans.
2. SVI: Yes there are Layer 3 interface. this means Switch Virtual Interface (interface vlan)
3. haveing the quarantine vlan as default will be for all switches and ports where you want to implement dot1x (then yes on core if you have some users connected on it and yes for access)
Here some documentation on how to configure your switch for 802.1x:
- IBNS 2.0: https://www.cisco.com/c/en/us/products/collateral/ios-nx-os-software/identity-based-networking-services/whitepaper_C11-729965.html ==> With version 12, it's not gonna work
- Legacy: https://community.cisco.com/t5/security-documents/cisco-ise-wired-access-deployment-guide/ta-p/3641515
You will learn by reading them instead of copy/paste a posted config.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
5 Replies 5
Hi Tim,
Thanks for your prompt response, i check the link but couldn't find proper solution, I am looking for a switch configuration from start to end.
Sajid
Francesco Molino
What exact version are you using and what exact model? I'm asking this to give you a config snippet using legacy or IBNS2.0 (if supported).
At high level:
- you create vlans on both core and access switches
- you create your SVI on your core switch
- You can pre-setup all ports to be in quarantine vlan and then you'll change it depending on your posture status.
Francesco
Hi Francesco,
Thanks for your response.
Please find below details.
Core Switch : Cisco IOS Software, C3560 Software (C3560-IPSERVICESK9-M),
Version 15.0(2)SE11
Access Switch : Cisco IOS Software, C3560 Software (C3560-IPSERVICESK9-M),
Version 12.2(52)SE, RELEASE SOFTWARE (fc3)
Please find below response in Green Text.
You mean to say that i need to create all four Vlans on both switches, is it
You mean to say L3 Interface ( Interface VLAN X). Right ?
This should be on core switch or Access Switch
Thanks.
Francesco
