3850 switch will not enter ROMMON mode
KMNRuser
We are trying to get a configuration off of an older, no longer in production 3850 (C3850-48T).
I am following instructions which is to say that i have:
1.  Depressed and held the mode button down while plugging the switch into AC power.
2.  Wait and watch 12-15 seconds until SYS light turns amber, then release the MODE button.
2 Accepted Solutions
Not that we see you presses the Mode Button to reset .
if you press the button you sure see the switch: (prompt)
another  blog for reference to get switch:
https://www.rogerperkin.co.uk/cisco/password-recovery/password-recovery-cisco-catalyst-3850/
BB
KMNRuser
We were able to use this document https://www.rogerperkin.co.uk/cisco/password-recovery/password-recovery-cisco-catalyst-3850/ and do a password reset.  The only procedure that worked was:
1.  Plug in the 3850 WITHOUT holding the Mode button.. you have to focus on it, and once it turns from Amber to Green and starts flashing** THEN depress the MODE button and hold it (i timed it > it took 80 seconds) until such time as all 4 FP LED's turn AMBER.. then release MODE button..  Then we were at the switch: prompt and could do what was needed to do to reset passwords and recove the box.
balaji.bandi
Can you connect the console and post complete boot log while you trying to press the reset button and released.
follow below steps :
https://community.cisco.com/t5/networking-knowledge-base/password-recovery-on-cisco-catalyst-3850/ta-p/3154378
BB
Balaji,
Thank you for your response.  I have attached the log output.  it is almost as if the Mode button is inoperative.  I feel it depress, but there is no indication in the output that the MODE button is ever pressed..
BB
KMNRuser
