01-08-2013 10:28 PM
Hi , I want to configure my 7206VXR router with EEM , which can depend the " status of track " make action .
The current version is c7200-jk9s-mz.124-12c.bin , seems can only depend on the syslog .
Solved! Go to Solution.
01-08-2013 10:29 PM
Correct, you will need 12.4(2)T or higher to get the track event detector. You should be able to run up to 12.4(24)T on this router.
01-10-2013 10:38 AM
If AAA command authorization is configured, the username for EEM must be configured using the 'event manager session cli username
The authorization bypass feature allows the admin to say, "I don't want EEM to run things through AAA command authorization." So when an action cli command tries to execute a cli command and AAA command authorization is configured, the authorization step is bypassed and the command is allowed.
Mike
01-12-2013 11:28 AM
You can't. The 7200 only supports up to EEM 3.0 and you need EEM 3.1 for AAA bypass. However, there is a workaround documented at https://supportforums.cisco.com/docs/DOC-12757#EEM_and_AAA_Command_Authorization .
01-12-2013 06:10 PM
Ah, 15.x is supported on the 7206VXR. I think I was thinking of the standard 7206 that ended at 12.4T. Yes, these images require 512 MB of RAM, so you will need to upgrade the memory in your router.
01-08-2013 10:29 PM
01-08-2013 10:31 PM
Hi , thank you so much for so quick reply .
01-10-2013 01:34 AM
event manager applet TEST authorization bypass
what does "authorization bypass" mean...
I have configured AAA on my router , Does EEM need username and password when excute the action....
I debuged event manage action cli , EEM still worked , no need to use username and password , I just want to confirm with you.
Thank you !
01-10-2013 10:38 AM
Mike
01-12-2013 08:34 AM
Would you please let me know if I want to use EEM authorization bypass feature , which IOS version I should use on my 7206VXR Route.
Thanks a lot.
01-12-2013 11:28 AM
01-12-2013 05:58 PM
Thanks a lot about your reply. :)
I have another question. It is not about EEM. It is about the upgrade on my 7206VXR.
This route have only 256M memory. I want to upgrade to 15.1(4)M5, but seems that this version need at least 512M memory. Am I right.....if it is true, I should find another version.
01-12-2013 06:10 PM
01-12-2013 06:19 PM
.....Need to upgrade memory, bad news, but thank you for you help : )
