AAA for authentication and priv levels - which software?
carl_townshend
Hi All
We would like to do some authentication and authorization on our Cisco routers and switches.
We were looking at Windows NPS (Radius), however I believe that we cannot really do any authorization of commands and it is limited.
What other servers can we use for this, I guess we will need Tacacs? would we need Cisco ISE, or are there other ones out there?
cheers
Seb Rupik
I have used this product to good effect in the past:
https://tacacsgui.com/
cheers,
Seb.
Jaderson Pessoa
I really suggest Cisco ISE i've used it and it is magic about what we can do :)
Jaderson Pessoa
*** Rate All Helpful Responses ***
balaji.bandi
As @Seb Rupik suggested you can use that one or if organization able to invest, do ISE (but if the devices are few up to 10 - not large, then the investment is not greate) - i would also look free radius.
MS NPS, ok you can do what you looking but not as easy as compared to other products if the user in Active directory.
then check the below guide : ( i used for one of the clinet it works, i like ISE / ACS (no longer) / Freeradius (if opensource prefered)
https://blog.skufel.net/2012/06/how-to-integrating-cisco-devices-access-with-microsoft-npsradius/
BB
