Bookmark
Subscribe
2154
Accessing the Sybase DB via web interface
mark.margolin
Does anyone have the URL and login details for the Web interface to the Sybase DB?
I have corrupt syslog entries that need to be groomed out. This has caused SYSLOG to stop collecting.
Cheers,
MM
6 Replies 6
nhabib
Level 9
Level 9
Which version of RME are you running? On what platform?
It is run on Windows and is version 3.4
What is the size of your CSCOpx\log\syslog.log file?
Do you know of the URL that I am referring to? If you dont it's Ok. I will raise a TAC case.
Yes I do. You need to login as admin first, then go to:
http://server:1741/dbreader/dbreader.html
I suspect that your syslog.log might be large and that is what is causing the issue
Thanks for the URL the username and password are as follows:
username: dba Password: c2ky2k
you will also require the Database such as 'rme'
