11-01-2010 08:32 AM
We use RME Version 4.3.1. ACE-Modul has SysObject-ID .1.3.6.1.4.1.9.1.1291.
Is this Modul supported?
Hansruedi
Solved! Go to Solution.
11-08-2010 01:40 AM
Hi Hansruedi,
This device currently isn't supported in any version of LMS.
If you need support for this device I would go ahead and contact your Cisco Account Manager and ask them to open a Product Enhancement Request to have support for this device added to LMS.
You can check at the following for the list of currently supported devices in RME 4.3.1:
Best regards,
Shane
11-08-2010 01:40 AM
Hi Hansruedi,
Best regards,
Shane
11-15-2010 07:32 AM
Hi Shane,
Thank you very much for your help.
Hansruedi
