Allowing single port to communicate with multiple VLANs on Cisco SG350-28
Tuhi
I have a Cisco SG350-28 switch with me. The requirement here is to connect 4 PLC devices and a computer device (server) on the switch.
However, I only want the server to be able to communicate to these 4 devices and these 4 ports on which these PLC devices are connected should not be able to communicate with each other.
In nutshell, if from port 1-4, PLC devices are connected and on 5th port server device is connected then traffic should be allowed as below: -
1) 1 <-> 5
2) 2 <-> 5
3) 3 <-> 5
4) 4 <-> 5
Below traffic should not be allowed : -
1) 1 <->2/3/4
2) 2 <->1/3/4
3) 3 <->1/2/4
4) 4 <->1/2/3
Please suggest how to configure the switch to achieve this configuration.
5 Replies 5
marce1000
                - Is it questioning  broadcasting-time , or do you want to stay real ?
 M.
Didn't get your question regarding broadcasting-time.
The communication should happen in real time only.
marce1000
 - Actually I need to apologize for these remarks, guess my morning coffee was from a bad brand, I confused the group-name , with your username. Apologies again, will look into your question.
 M.
That's okay. Looking forward for suggestions
marce1000
 - You may want to use private vlan(s) for this - have a look at this document :
                     https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-small-business-300-series-managed-switches/smb5659-configure-private-vlan-membership-settings-on-a-switch-throu.html
 M.
