Another syslog question -
getwithrob
Level 7
Level 7
We want to configure logging to log messages to a syslog server. However, we only want severity levels 3,2,1 and 0 to go to the server. Will this affect the severity levels that go to the buffer? We still want 7,6,5,4,3,2,1 and 0 to go to the buffer.
command syntax for a switch running CatOS
set logging server enable
set logging server 172.30.230.150
set logging level all 3 defaul
nhabib
Level 11
Level 11
set logging server severity 3
set logging history severity 7
nhabib
Level 11
Level 11
Thank you.
You're awesome.
