ASA 5510-K8 upgrade
grey580
I have an ASA 5510-K8 that is running ASA Version 9.1(5) & ASDM 7.3(1)101 that I need to upgrade.
What options do I have to upgrade this guy?
And how do I upgrade?
Ben Walters
Level 4
Level 4
You are not too far off the latest version at 9.1.5, the newest is 9.1.7 you will have to download the ASA software from Cisco.
This is for the ASA and ASDM:
https://software.cisco.com/download/home/279916854/type/280775065/release/9.1.7%20Interim
https://software.cisco.com/download/home/279916854/type/280775064/release/7.9.2.152
Once you have the files you need you can use either the ASDM or CLI to upgrade, ASDM is much easier but here is a guide for both:
https://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/200142-ASA-9-x-Upgrade-a-Software-Image-using.html
You may also want to note that the end of support for that device in September of this year so after that there will be no more software released for it.
5 Replies 5
Ben Walters
Level 4
Level 4
And if I wanted to upgrade to a new device. What would be a good replacement for the asa 5510?
Is there someone I could reach out to to figure out what's a good option and pricing?
Hello!
That device is too old, the best option you have is Cisco ASA 5516-X in order to replace it, you can review all the device information here: https://www.cisco.com/c/en/us/support/security/asa-5516-x-firepower-services/model.html
Please do not forget to rate useful post.
Best Regards,
looking at the upgrade path.
Am I safe to assume that I can upgrade from my current version to the latest version asa917-29-k8.bin in one go? Without having to upgrade to something in between?
Hello!
No, because your courrent version is not too old compared to the recomended one, so you can go directly to 9.1.7 without problem.
Best Regards,
