06-10-2023 04:01 AM
Hi all,
Having just upgraded my ASA to version 9.18, I'm now no longer able to ping the inside interface through the VPN.
From the ASA I can no longer ping inside (then my internal network)
On version 9.16 this was fine.
The management inteface is still the inside. Nothing has changed since the upgrade.
ICMP is allowed on the interface.
NAT is not causing any isses.
Firewall rules are all open.
I did the upgrade so I could use SNMP properly as they added loopback interfaces as with version 9.14 they messed up the SNMP so had to do a workaround to make SNMP work.
I think there's some quirks with this new version Cisco has launched and I'm wondering if this is now one of those.
Does anyone have any similar experience with this?
Many thanks.
James
06-10-2023 04:08 AM
you need management-access INside add to ASA under the INside interface
06-10-2023 04:12 AM
Thanks MHM but I did mention that it is already set in my post above.
This is something that has changed in this ASA version.
06-10-2023 04:15 AM
can you share the config
