Assign IP address to port
assign IP address to port
hello everyone
I am something new in networking and I want to find out if a switch of the catalyst line can be configured a port to assign only an IP address? If so, what is the procedure to do it or what source do you recommend?
thank you
5 Replies 5
Mark Elsen
                                   - You can only do that on a l3 switch , here is an example :
switch(config)# interface ethernet x/y
switch(config-if)# no switchport
switch(config-if)# ip address 192.0.2.1/8
balaji.bandi
what is the device model IOS.
in general
config t
interface gi 0/1 -- change this as per requirement
no switchport  -- this convert port to layer 3
ip address 10.10.10.1 255.255.255.0  < -- change this as per requirement.
no shutdown
end
BB
Hello
do the configuration of the switch as indicated to me (see switch image) with an ip address 192.168.1.10, however, the IP address of the computer (see ipPC image) is different from the one configured in the port and there is communication, however In this scenario, should the switch reject the communication?
if the PC connected to port Fas0/1 ( this is layer2 port)
PC should able to ping 192.168.1.10
BB
Perhaps there is something in the post that I am not understanding. When I look at the image showing switch I see an interface with an IP v4 address. When I look at the image showing PC I see the PC is configured with an IP v4 address that is in the same subnet as the switch address. I would expect the PC and the switch to be able to communicate using IP v4. Is there some reason why you would expect the switch to reject the communication?If so please explain to me what you believe the issue to be.
Rick
