Bookmark
Subscribe
1431
Automatic Backup solution for Cisco devices.
spbalakrishnan
Can anyone have an idea about taking automatic daily backups of cisco Ios images?..Any tool is available for that? Iam trying to take automatic daily back of my network devices. I tried with "configsafe" but that is not working..please help if any tool is available in the net.
kyawzawhtut
Cisco Lan Management Solution can do for you. More specifically, Resource Manager Essential, which is part of the LMS bundle. You can schedule not just to backup IOS image as well as config as well.
Cheers.
David Stanford
Have a look at the user guide for Resource Manager Essentials. This will give you a good idea of what you can do with the product on your devices with regards to config management:
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000e/e_4_x/4_0_3/u_guide/index.htm
a_harkati
Try Kiwi enterprise Kat tool. It's doing real good job. you can group devices into different databases. and schedule automatique backups. It support a with range of vendors (Cisco, 3COM, HP, etc..)
Thanks, Iam planning for KIWI.
