Bandwidth monitoring
madlm
Can anyone recommend a bandwidth monitoring tool that can monitor specific router and switch interfaces and also provide real time and report logging? I need something that won't break the bank but does a good job. I would purchase Ciscoworks but unfortunately our company cannot afford it.
best regards
nhabib
Level 9
Level 9
MRTG is a popular tool, and it's free:
http://www.mrtg.org
boblee
Hello madlm
you can use MRTG to do it.for detailed info ,pls search it in the goolge.
Regards!
