10-11-2022 11:08 PM
Hi all,
Looking for a definite answer for stacking for C9300-24UXA with C9300-48U-A
I'd been puzzled by the statement in the guide.
Does it consider the same model?
Solved! Go to Solution.
10-11-2022 11:58 PM - edited 10-12-2022 12:01 AM
those model can stack together (except 9300L)
you can refer to architecture :
10-12-2022 01:36 AM
good question...the guide you have linked to does not provide a definitive answer, it can only be assumed that the C9300-24UXA wand the C9300-48U-A can be stacked, as they are not mentioned in the restriction below. Then again, assumptions are usually a bad thing. I'll try and find a definitive answer...
--> C9300-24UB, C9300-24UXB, and C9300-48UB switches can only be stacked with each other.
12-06-2022 01:16 AM
We check with our local dist.
C9300-24UXA and C9300-48U-A is able to stack.
12-06-2022 01:56 AM
good to know, thanks for the feedback !
