C9300 stack prerequisites statement
owen2
Hi all,
Looking for a definite answer for stacking for C9300-24UXA  with C9300-48U-A
I'd been puzzled by the statement in the guide.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/17-8/configuration_guide/stck_mgr_ha/b_178_stck_mgr_ha_9300_cg/managing_switch_stacks.html
Does it consider the same model?
balaji.bandi
balaji.bandi
those model can stack together (except 9300L)
you can refer to architecture :
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/white-paper-c11-741468.html
BB
good question...the guide you have linked to does not provide a definitive answer, it can only be assumed that the C9300-24UXA wand the C9300-48U-A can be stacked, as they are not mentioned in the restriction below. Then again, assumptions are usually a bad thing. I'll try and find a definitive answer...
--> C9300-24UB, C9300-24UXB, and C9300-48UB switches can only be stacked with each other.
We check with our local dist.
C9300-24UXA and C9300-48U-A is able to stack.
good to know, thanks for the feedback !
