C9500-24Y4C in Switchstack Virtual Upgrade
ScottDawson2051
Visitor
Hi All,
I have a pair of 9500-24Y4C's running in switchstack virtual mode on Gibraltar 16.12.4 , I believe Amsterdam 17.3.4 is the current version we should be on.
I have 2 questions.
How long does the upgrade process take ? - These switches are running as a Core in a Cusotmer Contact centre and just need an idea on total down time.
Can I upgrade direct from 16.12.4 to 17.3.4 and does anybody have any real would upgrade guides ?
Ta.
balaji.bandi
what is the reason for the upgrade?
when you upgrade from 16 to 17, there is a micro code upgrade required, read the release notes before upgrading and understand the caveats, some time hard to revert back, (means need more downtime).
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/17-3/release_notes/ol-17-3-9500.html#concept_ycv_jdf_3mb
upto 40minutes both upgrade
BB
