Call Home on Nexus 5548
johnnylingo
Level 5
Level 5
I'm trying to configure Call Home on a Nexus 5548, software version 7.0(6)N1(1).  Below is the configuration:
vrf context management
  ip domain-name mydomain.com
  ip name-server 192.168.100.100
  ip route 0.0.0.0/0 192.168.100.1
callhome
  site-id MySite
  email-contact me@mydomain.com
  phone-contact +1-408-555-1234
  streetaddress 4900 Marie P DeBartolo Way, Santa Clara, CA 95054
  transport email smtp-server smtp.mydomain.com port 25 use-vrf management
  transport email from callhome@mydomain.com
  transport email reply-to callhome@mydomain.com
 enable
I can ping the SMTP server, so DNS and connectivity via the VRF is working:
# ping smtp.mydomain.com vrf management
PING smtp.mydomain.com (10.10.10.10): 56 data bytes
64 bytes from 10.10.10.10: icmp_seq=0 ttl=61 time=0.813 ms
64 bytes from 10.10.10.10: icmp_seq=1 ttl=61 time=0.801 ms
However, when sending a test call-home message, I don't even see it connecting to the SMTP server.
Similar configuration on 6500s and ISRs works fine, so think I'm just missing something.
jmandersson
Have you enabled the service with service call-home?
Johan
That's an IOS command.  This is Nexus.
johnnylingo
Level 5
Level 5
Found a nice blog post that pointed out the SNMP contact must be set for callhome to work:
http://www.jvocke.com/configure-callhome-on-a-nexus-50007000/
Still no luck though.  I suspected that DNS may not be working correctly on the VRF, so tried referencing the SMTP server using IP address.  That didn't help either.
johnnylingo
Level 5
Level 5
Found there's a funny quirk about the Nexus line.  Destination Profiles must be created before any test will work.  TAC recommend creating the CiscoTAC-1 profile and doing registration.
callhome
  destination-profile MyProfile
  destination-profile MyProfile format short-txt
  destination-profile MyProfile email-addr target@mydomain.com
  destination-profile MyProfile alert-group all
destination-profile CiscoTAC-1 email-addr callhome@cisco.com
enable
