Can I use ASUS Home Router with Cisco ISR 1100?
whughes123
I purchased a Cisco ISR 1111x-8p router for my business, but I did not know I needed to purchase a WIFI card with it to provide WIFI coverage for my building. Now I am stuck with a router that does not provide WIFI capabilities. My question is, can I use my existing ASUS home router (connected to ethernet port) and control security/management (port-security, ACL, etc) for the devices connecting to WIFI from the Cisco router? Or is there someway I'm not aware of to give this thing Wireless capabilities?
I have attached a network diagram to show what I'm talking about...
Thank you!!
liviu.gheorghe
Hello @whughes123 ,
the short answer to your question - Yes you can use the Cisco ISR 1111 to connect to the internet and have the ASUS connected to the router. You will need to configure a series of things:
  • PPPoE for the connection to the ISP (most probably)
  • some static and/or default routes
  • NAT for the wireless subnet
  • ACL's for security
just to name a few.
Regards, LG
*** Please Rate All Helpful Responses ***
@liviu.gheorghe  Awesome! Just to be clear again, I can control WIFI access to the Asus WIFI network THROUGH the Cisco ISR 1100 router interfaces via port-security or ACL or whatever. So if I setup DHCP in the 192.168.1.x range for all computers in the building to connecting to the Asus router via WIFI, I can control that access from the Cisco ISR router?? Or whatever the most secure way of setting this WIFI access up is through the Cisco ISR router?
Yes you can. ACL's would be your tool to do that. You would have to do it on a SSID/VLAN basis, unless you assign static IP addresses through your DHCP.
Suppose you have SSID Management, which gets IP's from subnet 192.168.1.x - the ACL on the router will allow IP's from 192.168.1.x access to the Internet.
Now you have another SSID - Accounting, which gets IP's from subnet 192.168.2.x - you configure the ACL on the router to deny IP's from 192.168.2.x access to the Internet.
Regards, LG
here is what the ISR1100 basic config would look like. Your ASUS router probably serves as DHCP server for one or more (wireless or wired) subnets. Set the ASUS WAN IP address to 192.168.2.1/24, so it connects to the ISR. The ISR will NAT anything in the 192.168.0.0/16 range.
version 16.9
service config
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname NEXUS-1
boot-start-marker
boot-end-marker
enable secret 5 XXXXXXXX
enable password XXXXXXXX
no aaa new-model
subscriber templating
crypto pki trustpoint TP-self-signed-2759056948
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2759056948
revocation-check none
rsakeypair TP-self-signed-2759056948
crypto pki certificate chain TP-self-signed-2759056948
certificate self-signed 01 nvram:IOS-Self-Sig#5.cer
license udi pid C1111-8P sn XXXXXXXX
no license smart enable
diagnostic bootup level minimal
username YYYYYYYY privilege 15 password 0 XXXXXXXX
redundancy
mode none
interface GigabitEthernet0/0/0
description Uplink to Internet
ip address dhcp
ip nat outside
interface GigabitEthernet0/0/1
description Downlink to ASUS Router
ip address 192.168.2.2 255.255.255.0
ip nat inside
interface GigabitEthernet0/1/0
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
interface GigabitEthernet0/1/4
description SkyNET
switchport access vlan 200
interface GigabitEthernet0/1/5
interface GigabitEthernet0/1/6
interface GigabitEthernet0/1/7
interface Vlan1
no ip address
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http client source-interface GigabitEthernet0/0/0
ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.1.1 GigabitEthernet0/0/0
snmp-server community XXXXXXXX RO
access-list 1 permit 192.168.0.0 0.0.255.255
control-plane
line con 0
transport input none
stopbits 1
line vty 0 4
password XXXXXXXX
login
end
