Cant activate POE cisco catalyst 9200-48t-4x
R1nzler
Hello all,
i've been trying to configure a port to use POE on a Forti AP.
i've see the configuration and when i try to configure the power inline on the port i cant and the only option i have is " efficient-ethernet"
Hey R1nzler,
The Catalyst 9200-xxT models do not have PoE capabilities.
Only the P-variants of the switches do have PoE.
For reference, check Table 3 here or Table 19 in the "Ordering" tab:
Cisco Catalyst 9200 Series Switches Data Sheet - Cisco
balaji.bandi
9200-48t-4x  - check model collectly - T means DATA only
P-PB-PXG is for PoE
BB
