CCIE LAB server Recommendation
laxmicisco
HI,
i want to but a server for my CCIE preparation .so which server i should buy for my ccie LAB preparation .
Please recommend me for my CCIE preparation .
Any PC that can run the likes of VIRL or Full GNS3 and IOU will work , you want 16GB ram at minimum i7 processor or better as there could be up to 25 IOU devices in config LABs , anything less than that you may struggle operating large amounts of gear virtually
balaji.bandi
Here is the one of Workstation i have purchased play for the Labs and PoC
http://www.balajibandi.com/2016/05/12/ccie-lab-preparation-got-the-workstation-time-to-play/
BB
hi,
is it Rack server or Tower server ??
what would be costing of this server in india ??.
is below mentioned model will support the CCIE LAB ??.
New Dell PowerEdge Tower Model T30 / Single 1 x Intel® Xeon®
E3-1225 v5 (3.3GHz/4c/8MB/80W) / 1 x 16GB
RAM Memory / HDD up to 4 drives (3.5 inch) SATA / 1 x 1TB SATA (3.5
inch) 7.2k RPM / RAID On-board / optical DVD Writer / RPS 1x
inbuilt (290W)
Thanks .
Mine  was Workstation,  If you looking only CCIE RNS, all virtual, IOU you can run on Laptop with 16GB RAM. ( i was suggested to invest some good money, so you can use for other labs practicing, any track)
As other post suggested any Old i7 with 16GB ok, but i suggest 32GB ram good to start. make sure VTx support.
If you are in india, many refurbished available in Delhi market or local vendors.
BB
