Network Management
Labels
My main question is it possible to create an RSPan where source ports are location on sw1 and sw2 with the destination port to a remote collector also resides on sw 2. And two what would the commands be?what i was thinking was this:SW1 :vlan 999 remo...
egr1985 by Level 1
  • 194 Views
  • 4 replies
I need some help guys! So we are tasked to figure out DHCP as a school work, and the first part is the DHCP standard. So here comes the next part, as you can see in Networks 1 and 2, they are connected and have DHCP service at Server 1. So the task t...
nixb by Level 1
  • 990 Views
  • 13 replies
