Cisco Catalyst 9200L Default Login for Managing Switch
PentaSupport
Simple Question. I am having difficulty logging into a new cisco switch to manage the switch directly. I am able to get to the login, but I am unable to log into the switch using the default information U: Cisco P: SN on switch. Am I missing something? It says the chassis SN, where is that located? If it is in anyway different from the SN that is visible from the top of the switch. The switch is a Cisco Catalyst 9200L 24 4x1G. We routinely order large amounts of them, but this is the first time that we need to manually manage one.
balaji.bandi
here is the document :@
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9200/hardware/install/b-c9200-hig/b-c9200l-hig_chapter_0110.html
Step 4
Launch a web browser on the PC and enter the device IP address (https://192.168.1.1) in the address bar.
Step 5
Enter the Day 0 username webui and password serial number. Note that the serial number is case sensitive.
BB
9 Replies 9
Jaderson Pessoa
The default username is cisco ; the default password is the serial number of the switch chassis.
If not work, try user: cisco and password: cisco / password
Jaderson Pessoa
*** Rate All Helpful Responses ***
hi dear
can you help me the how to enabling POE
thanks
Not sure understand the question here correctly - follow below URL how to ask question - so people can address correctly.
explain your setup - Model of the switch - by default PoE enable if you purchased PoE switch.
BB
Thanks for the update
Jaderson Pessoa
Log on using the default username and password provided with the device.
The default username is cisco ; the default password is the serial number of the switch chassis. For Cisco Catalyst switches running software versions earlier than Cisco IOS XE Fuji 16.9.x, the default username is webui ; the default password is the serial number of the switch chassis.
Jaderson Pessoa
balaji.bandi
Step 4
Step 5
BB
We need to create a username and password from console to use for web login,
username admin priv 15 secret password123
 it worked for me.
tsega gebeyehu
Thanks for the update. According to your answer, this Cisco device have been crated username and passwords even working for 1 year, but I would have used the previous web Ui interface when I started but now you can't open the web Ui this is my enquiry.
thanks for your help.
janit
I had to disable https secure server
ip http server
ip http authentication local
no ip http secure-server
