Cisco CNR config check
true4true
Hello
Is it possible to check config before using it?
CNR ver 8.0
OS RHEL 6.2
Ganesh Kondaveeti
Hi Rustam,
You may refer to following links for the answer for your question.
Installation Guide -Upgrading on Solaris/Linux
http://www.cisco.com/en/US/docs/net_mgmt/prime/network_registrar/8.0/installation/guide/IGinstup.html#wp1227462
System Requirement
http://www.cisco.com/en/US/docs/net_mgmt/prime/network_registrar/8.0/installation/guide/IGoverv.html#wpxref70927
K. Lakshmi Ganesh
Ganesh Kondaveeti
Hi Rustam,
- Cisco  Prime Network Registrar is supported on 32-bit and 64-bit operating  systems. Only 32-bit Red Hat Enterprise Linux ES 6.0 is supported.
- Cisco  Prime Network Registrar 8.0 supports Red Hat Enterprise Linux ES 5.0,  Red Hat Enterprise Linux ES 6.0, and Windows Server 2008, running  standalone or on VMWare (ESX Server 4.1) on Cisco Unified Computing  System (CUCS) and other hardware supported by VMWare.
K. Lakshmi Ganesh
