04-02-2013 08:58 AM
We use LMS Prime 4.1 Soft Appliance.
on the 23rd of March, the disk ran full and LMS crashed. After investigating and rebuilding database according to instructions, a lot is up- and running again except for the ANIServer.
Currently the ANIServer status: Administrator has shut down this server, ProcesStartTime date/time 04/02/13 17:03:53 ProcessStopTime
04/02/13 17:03:54
So it immediately stops and nothing is put in the log of ANIServer.log
If I goto report-->System-->ANI Server Analysis I get the error message: Unable to fetch information from ANIServer
System Informations --> Null, Configuration settings --> Null and Raw analysis --> Null
How can I resolve this issue?
ANIServer log of the 23rd:
2013/03/23 12:23:05 Daemon Manager ani ERROR DBConnection: Failed to acquire metadata for connection because of null DB connection
2013/03/23 12:23:05 Thread-24213 ani ERROR DBConnection$ConnectionCreator: Failed to establish DB connectivity because: java.sql.SQLException: [Sybase][ODBC Driver][SQL Anywhere]Disk full 'Fatal error: disk full when writing to "/opt/CSCOpx/databases/ani/ani.log"' -- transaction rolled back
java.lang.NullPointerException
at com.cisco.nm.ani.server.framework.DBConnection.statement(DBConnection.java:113)
at com.cisco.nm.ani.server.frontend.AniMain.clearDcrpTable(AniMain.java:1055)
at com.cisco.nm.ani.server.frontend.AniMain.exit(AniMain.java:1281)
at com.cisco.nm.ani.server.frontend.dMgtRunner.run(AniMain.java:810)
at com.cisco.nm.ani.server.framework.DBConnection.commit(DBConnection.java:161)
at com.cisco.nm.ani.server.frontend.AniMain.clearDcrpTable(AniMain.java:1065)
ShutDown requested from the Cisco Process Manager
2013/03/23 12:23:05 Daemon Manager ani MESSAGE AniMain: Unpublishing CM Northbound API...
2013/03/23 12:23:06 Daemon Manager ani MESSAGE AniMain: Unpublished CM Northbound API.
04-03-2013 04:51 AM
Hi ,
Try the below steps:
1) Stop the Daemon Manger /etc/init.d/dmgtd stop 2) cd /opt/CSCOpx/databases/ani Remove/rename ani.log (if exists)
3. If Solaris:
env LD_LIBRARY_PATH=/opt/CSCOpx/objects/db/lib64 /opt/CSCOpx/objects/db/bin64/dbsrv10 -f /opt/CSCOpx/databases/ani/ani.db
If Softappliance:4. Start the Daemon Managerenv LD_LIBRARY_PATH=/opt/CSCOpx/objects/db/lib64 /opt/CSCOpx/objects/db/bin64s/dbsrv10 -f /opt/CSCOpx/databases/ani/ani.db
/etc/init.d/dmgtd start
If above does not work then send the below information:
ani.log,aniserver.log and AniServer.properties
Afroz
04-04-2013 07:34 AM
Hello Afroz,
Problem was with ANIServer.properties file, this file got corrupt.
Thanks for your support.
Henk
