Cisco Nexus 31108TC-V - PTP Routing
we have a  Cisco Nexus 31108TC-V switch and we need to configure the switch in order to route the PTP packets on 100G ports. we know that this switch doesn't support PTP on 100G port, but we are wondering if there is a way to configure the switch in order to route all the packets on 100G without check the packet content. Maybe we cannot achieve the best PTP accuracy, but we don't need very high accuracy.
Thank you in advance for the support.
FM
5 Replies 5
balaji.bandi
can you please clarify what is the context of PTP Routing ( Point to Point or Precision Time Protocol (PTP),)
https://www.cisco.com/c/en/us/products/collateral/switches/nexus-3000-series-switches/white_paper_c11-690975.html
BB
With PTP I refer to Precision Time Protocol
then guide i was referring still valid. or i miss something here ?
BB
The problem is that we cannot configure the switch to routing PTP packet on 100G ports. We know the PTP cannot be enable on 100G ports, but we hoped that there is a way to configure the Switch so that it can handle PTP packet as general UDP packets without check their content and route them on 100G ports. So far we have not found a way to do it. Any advice is welcome.
I try with different question: does anyone know if it is possible to configure the switch so that it routes all the packets (of corse based on destination MAC) from/to 1G port to/from 100G port as a layer 2 switch?
