Cisco Nexus 3548 - NetFlow
a.aljiledi
Dears..
i have Cisco Nexus 3548 , and i try to enable netflow or sflow but i get these error
switch(config)# feature sflow
feature sFlow is not supported in this platform
switch(config)# feature netflow
Error: unknown feature
Switch Version
Software
BIOS: version 5.0.0
NXOS: version 9.2(2)
BIOS compile time: 05/22/2018
NXOS image file is: bootflash:///nxos.9.2.2.bin
NXOS compile time: 11/4/2018 21:00:00 [11/05/2018 06:11:06]
Hardware
cisco Nexus3500 C3548P-10GX Chassis
so there is any way to enable sflow or netflow on this product ?.... or any feature provide the same goal...
Any Idea??
it used to be a hardware limitation and apparently still is. Neither the Nexus 3524 nor the Nexus 3548 are sFlow capable, unfortunately...
balaji.bandi
Not tested by myself, since Nexus 3K most used in Low Latency environment,  (it was old when i was working with them on 7.X not seen that support)
Interestingly Nexus  OS 9.3 have some enhancement :
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus3000/sw/command/reference/931m3k/config/b_N3K_Config_Commands_93x_n3k/b_N3K_Config_Commands_93x_n3k_chapter_010101.html?bookSearch=true#wp1027752672
BB
