05-10-2017 05:15 AM
Cisco PI 3.1 chassis view is missing for a number of devices such as 4500x, 6500E and some other models , even with the device pack 10 installed.
Is something wrong with my server or these has not been provisioned yet.
Farooq
05-10-2017 09:36 AM
You need to check the device packs to see the OID that you have in your network. Goto: http://www.cisco.com/c/dam/en/us/td/docs/net_mgmt/prime/infrastructure/3-1/release/notes/pi31-device-pack-readme.pdf
And on the first page, click on "Viewing New Devices Supported". Verify if your device is there on that list.
Oh by the way, device pack 11 was out today :)
05-10-2017 09:43 AM
Chassis view is not included for many products.
Cisco has backed off from commiiting to that feature across the board after their experience with how much trouble it was to support CiscoView in LMS and predecessor products.
As noted in the Device Pack XLS file, the following features are supported for switches:
Cisco Switches (IOS) : Supported Features | |||||
Switches and Hubs | |||||
Configuration | Inventory | ||||
Access Control List Management | Spanning Tree Protocol | ||||
Controller Interfaces Management | VLAN Information | ||||
Etherchannel Management | Performance Monitoring | ||||
Interface Management | Device Availability | ||||
Inventory | QoS | ||||
Flash Information | CPU | ||||
IP Table | Interface | ||||
Image Information | Interface Availability | ||||
Interface details | Memory | ||||
Memory Pool Information | Topology | ||||
Physical Inventory | CDP Neighbor Discovery | ||||
Power Supply and Fan Status | LLDP Neighbor Discovery |
