Cisco Prime 3.10.4 Version Problem
m.soleimani
I installed Cisco Prime Infrastructure 3.10 and Patches as below but it still shows version 3.10.2, could you help me out with this issue?
Version : 3.10.2 [FIPS not Enabled]
Build : 3.10.0.1050.90
Installed Patches: PI 3.10.2 Maintenance Release
Critical Fixes:
PI 3.10.2 System Patch ( 1.0.5 )
PI 3.10.4 Maintenance Release ( 2.0.0 )
PI 3.10.4 System Patch ( 1.0.0 )
PI 3.10.4 Update 01 ( 1.0.0 )
marce1000
 - Ref : https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-10-4/release_notes/Cisco_Prime_infrastructure_3_10_4_Release_Notes/bk_cisco_prime_infrastructure_3_10_4_release_notes.html#Cisco_Concept.dita_4d69164d-6f59-4afa-88f5-68811cfeb38e
                      Presumably 4 only points to the maintenance index above 3.10.2
 M.
marce1000
 M.
ndahemmy
 I have a similar issue and i can't figure out how it was resolved on the shared link
reda-rayan
I have the same issue, and didn't find the solution on the shared link as well
