Cisco Prime 3.10.4 Version Problem
m.soleimani
I installed Cisco Prime Infrastructure 3.10 and Patches as below but it still shows version 3.10.2, could you help me out with this issue?
Version : 3.10.2 [FIPS not Enabled]
Build : 3.10.0.1050.90
Installed Patches: PI 3.10.2 Maintenance Release
Critical Fixes:
PI 3.10.2 System Patch ( 1.0.5 )
PI 3.10.4 Maintenance Release ( 2.0.0 )
PI 3.10.4 System Patch ( 1.0.0 )
PI 3.10.4 Update 01 ( 1.0.0 )
Mark Elsen
 - Ref : https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-10-4/release_notes/Cisco_Prime_infrastructure_3_10_4_Release_Notes/bk_cisco_prime_infrastructure_3_10_4_release_notes.html#Cisco_Concept.dita_4d69164d-6f59-4afa-88f5-68811cfeb38e
                      Presumably 4 only points to the maintenance index above 3.10.2
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
ndahemmy
 I have a similar issue and i can't figure out how it was resolved on the shared link
reda-rayan
I have the same issue, and didn't find the solution on the shared link as well
edonaghy1
Presumably the "solution" isn't really a "solution"
