12-25-2019 12:58 AM
Dear Team ,
i usually get job failed about Identity Services Engine Status
i don't know the reason for this error as show attached
thanks for help
Solved! Go to Solution.
01-02-2020 08:10 AM
Well, there's not much to adding the ISE server to prime - just username/password http timeout and port. Port is 443, timeout is 30.
Are you able to ping prime from the ISE monitor node ? Have you tried deleting the server from prime and set it back up?
Assuming no reachability issues and the proper id/pw, check the output of "ncs certvalidation tofu-certs listcerts" from prime. If the cert for your ISE server is listed, delete it using "ncs certvalidation tofu-certs listcerts" and then try re-adding it. If that doesn't work, it's a TAC case.
12-25-2019 04:39 AM
I believe the attachment is missed here.
please check the admin guide and check the config on the admin GUI of prime as per the below document :
12-26-2019 01:29 AM
12-26-2019 10:38 AM
Click on the job, click on the history or event should show the reason of failure.
12-29-2019 12:56 AM
hey,
the reason of failure : no data is available
i don't know how to resolve it
12-30-2019 03:42 PM
Under Administration > Servers > ISE Servers do you have your ISE servers setup there? They need to be the servers assuming the monitor personas if you have a distributed deployment. Is there status shown as reachable? If no to either question then I imagine it's normal for the job to fail.
01-02-2020 12:35 AM
thanks for you help , yes the status of Identity Services Engine server unreachable
Identity Services Engine update failed : Some unexpected internal error has occurred.
how to configure it correctly
01-02-2020 08:10 AM
01-05-2020 10:47 AM
Thanks so much for your help
12-07-2020 01:27 PM
it work for me,
to delete the old certificate use the cmd :
ncs certvalidation tofu-certs deletecert host <iseIPaddress_port>
thank you Y C.
