Showing results forĀ
Search instead forĀ
Did you mean:Ā
CISCO Prime 3.4 job Identity Services Engine Failed
Nadia Bbz
Dear Team ,
i usually get job failed about Identity Services Engine Status
i don't know the reason for this error  as show attached
thanks for help
Well, there's not much to adding the ISE server to prime - just username/password http timeout and port. Port is 443, timeout is 30.
Are you able to ping prime from the ISE monitor node ? Have you tried deleting the server from prime and set it back up?
Assuming no reachability issues and the proper id/pw, check the output of "ncs certvalidation tofu-certs listcerts" from prime. If the cert for your ISE server is listed, delete it using "ncs certvalidation tofu-certs listcerts" and then try re-adding it. If that doesn't work, it's a TAC case.
9 Replies 9
balaji.bandi
I believe the attachment is missed here.
please check the admin guide and check the config on the admin GUI of prime as per the below document :
https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-4/admin/guide/bk_CiscoPrimeInfastructure_3_4_AdminGuide/bk_CiscoPrimeInfastructure_3_4_AdminGuide_chapter_0101.html
BB
Dear Team ,
yes i missed attached
thanks for help
Click on the job, click on the history or event should show the reason of failure.
BB
hey,
the reason of failure :  no data is available
i don't know how to resolve it
Under Administration > Servers > ISE Servers do you have your ISE servers setup there? They need to be the servers assuming the monitor personas if you have a distributed deployment. Is there status shown as reachable? If no to either question then I imagine it's normal for the job to fail.
thanks for you help , yes the status of Identity Services Engine server unreachable
Identity Services Engine update failed : Some unexpected internal error has occurred.
how to configure it correctly
Thanks so much for your help
it work for me,
to delete the old certificate use the cmd :
ncs certvalidation tofu-certs deletecert host <iseIPaddress_port>
thank you Y C.
