Cisco Prime 3.5 - Use the HOSTNAME with CLI
cesacal
We have our devices configured to save the config on a tftp server, with these commands:
switchTest#show run
archive
path tftp://10.216.141.156/switchTest-
write-memory
I want to change this configuration, because our colleagues from server departament are changing the IP of the tftp server.
I´m new creating CLI Templates, and I want to use the switch own hostname, no a variable. Is it possible to do something like this:
archive
path tftp://10.216.141.156/${hostname}-
write-memory
And make the HOSTNAME to take the name of the switch dynamically?
Thanks for you help.
Jurgens L
Level 3
Level 3
Any specific reason why you don't use Prime's build auto-archive configuration?
To your question, the post below should answer this:
https://community.cisco.com/t5/switching/archiving-router-configuration-to-tftp-server-automatically/td-p/1288574
<<< Please help the community by marking useful posts helpful, or accept as a solution if it resolved your issue >>>
Jurgens L
Level 3
Level 3
Any specific reason why you don't use Prime's build auto-archive configuration? --> We are not Cisco Prime admins, we can do many tasks, but we do not have access to config on Prime.
Regarding the link, it solved my problem! Thanks a lot!!
