Cisco Prime 3.8 backup file does not match installed application
ciscoprolin
we have repeatedly upgraded our Cisco Prime server from 3.0 all the way up to 3.7.1 Update 02. However, to upgrade to version 3.8 as fresh install is needed with a subsequent Application Backup Restore from the old server running 3.7 to the newly installed one running 3.8.
We ran a server backup on the old 3.7 CPI server saving the backup to a remote SFTP repo. Then deployed a new Prime 3.8 Server (also on a VM via the 3.8 OVA file).
Next we performed a NCS reset:
ncs run reset
 followed by a restore of the Prime Server Application backup
restore backupFileName repository repositoryName application NCS
but in stage 3 (unpacking backup file) the restore failed with the error "Backup file does not match installed applications".
Does anyone know this issue and how to resolve it ?
Thorsten
Mark Elsen
 - Could you application restore,..   instead ?
 M.
bjmcveety
Having the exact same problem. Were you able to restore the backup?
 M.
