Cisco Prime 4.1 no syslogs in device view
fredareid
I am trying to figure out why the Device view has no systlogs in Cisco Prime 4.1
I have everything configured, the switch is sending debugging level logs to the IP of the Prime Server. I am fairly certain it is reporting because it has alot of other information in the server.
Any ideas?
Michel Hegeraat
Level 7
Level 7
First thing to check is if the SYSLOG messages arrive in the syslog.log file on the server.
Second is with what IP address are the message received.
I admit that I still haven't experimented as much as I should, but I think the SYSLOG sending IP address should match the management IP address of the device in LMS
So 'logging source-interface ' is best practive IMO.
Cheers,
Michel
