Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco Prime Configuration overwrite archive
lequi1963
Hi All,
Building manager are doing power maintenance over the Easter break.
We are going to lose power to hundred of switches.
I am trying to make sure every switches have their latest upto date configurations and
you can run a job-configuration-overwrite but the system only allow you to do 5 x switches at a time!!!
Not sure if I read it right or is there a way to do ALL switches at one go ?
Any suggestion are much appreciated.
Peter
You can create a CLI Templace with the command "wr" and apply to all switches. I think It will send in batches but is more then  5.
Hi Flavio,
Thanks you.
Yes , look like that is the way around it.
Do you have a url or steps to do it by any chance ?
I just don't want to make a silly mistake for something quite major.
Thanks everyone for for the response.
using WR command to backup.
All good.
balaji.bandi
