Cisco Prime Infrastructure 2.0 --> Third Party Devices
Marco Matera
Beginner
Beginner
we are using cisco prime infrastructure 2.0. Is it possible to manage third party devices? (We have a lot of Enterasys Switches)
When i want to Archive the config of the device there is an error --> No Device Package found for the specific device.
It is necessary to install device packages for third party devices? Where can i find and install these packages?
Thx in advance
Mahabir Prasad
Beginner
Beginner
Hi Marco
As i know for third party devices only snmp polling, snmp traps and syslog will work.
Config archive will not work. Device packages are only for cisco devices.
MAhavir
Is this a feature in the roadmap for future releases?
it seems not to be on the road-map according to the functional /feature comparison between LMS and PI 2.0:
http://www.cisco.com/en/US/partner/prod/collateral/netmgtsw/ps6504/ps6528/ps12239/guide_c07-729089.html
...and I doubt it will come (quickly) because config management has a lot of pitfalls and Cisco has a lot to do to get around all of them with their own devices..
However, Inventory Management for third party devices is on the road-map
older version of the document (feature comparison PI 1.2 - LMS 4.2) can be found here:
http://www.cisco.com/en/US/partner/prod/collateral/netmgtsw/ps6504/ps6528/ps12239/app_note_c27-716230.html
Recognize Your Peers
