cisco prime infrastructure 2.1 cannot see interface utilization
musikman_frank
Hi Experts,
I follow the cisco documents to check interface utilization in PI. (Operation >>Monitoring Dahsboards>>Performance>>network interface)
But I can't see anything in it. Does everyone come cross this issue? (or any others config to be need to add in PI system)
Please to check attachment to see the screenshot detail.
Thanks in advance,
/Frank
AFROJ AHMAD
Go to  "Deploy > Monitoring deployment "
make sure the "Interface Health (default)" is deployed to your devices.
Thanks-
Afroz
***Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
What is the equivalent on prime 2.2? I defined a monitoring policy, but only router ports are monitored.
In 2.2 go to Monitor > Monitoring Policies and add a Interface Health policy to your devices or port groups that you want to monitor.
Port groups can you create under Inventory > Grouping > Port
