Cisco Prime Requirements
TrickTrick
Level 3
Level 3
I'm new to cisco Prime installation and use, I would like to know what is required in client's environnement to install Cisco Prime, I mean by that does we need DNS, CA server ? NTP? are any of those mandatory ?
any specific mention about versions ? like DNS Windows 2012 and above are the only ones supported for example ? etc ...
In general I need to the my client what should exist in his environnement to install and configure cisco prime.
All I know now is he should open ports used for prime : SNMP, ICMP etc ...
Thank you in advance
balaji.bandi
Not sure what version 3.9 Latest and 3.10 on way ( either Physical appliance or VM)
Look at the installation guide all steps are clearly documented :
https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-9/quickstart/guide/bk_Cisco_Prime_Infrastructure_3_9_0_Quick_Start_Guide.html
BB
