Cisco router
srinivas12
On a same router, can we configure if one of the port goes down then the other port is down automatically.?
example :
event manager applet INTERFACE_DOWN
event syslog pattern "Interface GigabitEthernet0/0, changed state to down"   ( check this interfaces based on requirement)
action 1.0 cli command "enable"
action 2.0 cli command "config term"
action 3.0 cli command "interface GigabitEthernet0/1"
action 4.0 cli command "shutdown"
BB
6 Replies 6
 It is possible using EEM script but not using CLI command, if that what you want.
Where can i find it.? Can you attach here.?
example :
BB
Yes correct, I cannot do it via CLI ?
yes you configure via config more ( from console)
make sure you understand script and interface correct.
BB
balaji.bandi
Sure you can use EEM Script for this, monitor the SYSLog and shudown other interface.
Hope that works for you ?
BB
