Cisco Switch Ping Issue
AndrewGibbons8
Level 2
Level 2
Hey everyone,
I'm trying to configure some Cisco Switches to communicate with each other using two wireless radios as the bridge. I've attached a diagram of my current results/IP Scheme. I'm not sure why the switches can't seem to ping the radios and vice versa because on either switch when I input the "show cdp neighbors" command, both switches can "see" each other. Any advice?
balaji.bandi
As per your diagram Radios are in bridge mode and their IP is different, they do not know how to reach Switch IP.
As per your diagram, Switch B has a different IP range, compare to SwitchA  and Laptop A
Question is :
1. Is Laptop able to Ping Switch A ?
2. change the Switch B IP address so Switch A / B  / Laptop can able to communicate all.
make sense?
BB
balaji.bandi
Question is :
make sense?
BB
Gotcha, tried that and the switches can now communicate with each other fine. Thank you!
Thank you for the feedback, and good to know it sorted.
BB
