TACACS+ Configuration on nexus series
Scott12
Hello Everybody,
I'm configuration tacacs+ on nexus switches, but unfortunately something is wrong, or any command is missing. I would like to know what are the correct commands to configure this type of authentication.
PD
TACACS is running on ISE
Cheers
balaji.bandi
what kind of authentication - device authentication (hope that is what you looking)
here is the good guide to refer :
https://community.cisco.com/t5/security-documents/cisco-ise-device-administration-prescriptive-deployment-guide/ta-p/3738365#toc-hId-1977002717
or post your AAA configuration and give us more information about what is wrong?
BB
These are the commands that I've used.
feature tacacs+
tacacs-server host 10.10.20.10
tacacs-server key 7 **PASSWORD**
aaa group server tacacs+ **TACACS-GROUP NAME**
server 10.10.20.10
deadtime 30
tacacs-server directed-request
aaa authorization ssh-certificate default group **TACACSServerNAME**
aaa authorization commands default group **TACACSServerNAME**
I'm not sure if have missed a command.
Thanks in advance.
