09-01-2011 09:24 AM
When going to RME>Archive Management I get an HTTP 500 error. Our server person indicated no changes have been made, however there might have been an automatic push done by coprorate for windows patches. Has workd fine for years, then it failed yesterday.
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
java.lang.NullPointerException com.cisco.nm.rmeng.dcma.client.DBInterface.getDeviceSummary(DBInterface.java:1785) com.cisco.nm.rmeng.dcma.client.ConfigArchiveClientImpl.getArchiveSummary(ConfigArchiveClientImpl.java:811) com.cisco.nm.rmeng.dcma.ui.helper.DCMAArchiveViewUIUtil.getSystemDeviceArchiveInfo(DCMAArchiveViewUIUtil.java:1685) com.cisco.nm.rmeng.dcma.ui.action.DCMAArchiveSummary.perform(DCMAArchiveSummary.java:213) org.apache.struts.action.ActionServlet.processActionPerform(ActionServlet.java:1786) org.apache.struts.action.ActionServlet.process(ActionServlet.java:1585) org.apache.struts.action.ActionServlet.doGet(ActionServlet.java:491) javax.servlet.http.HttpServlet.service(HttpServlet.java:689) javax.servlet.http.HttpServlet.service(HttpServlet.java:802) com.cisco.nm.cmf.util.AccessLogFilter.doFilter(AccessLogFilter.java:128)
note The full stack trace of the root cause is available in the Apache Tomcat/5.5.17 logs.
com.cisco.nm.xms.ctm.common.CTMException: URN_NOT_FOUND : urn "JRM" : Not found !!
This error is from the RME.log.
LMS 3.2
Product Name | Version With Patch Level | Installed Date | ||
1. | Campus Manager | 5.2.0 | 18 Feb 2010, 06:11:55 PST | |
2. | CiscoView | 6.1.9 | 18 Feb 2010, 06:11:56 PST | |
3. | CiscoWorks Assistant | 1.2.0 | 18 Feb 2010, 06:11:56 PST | |
4. | CiscoWorks Common Services | 3.3.0 | 18 Feb 2010, 06:11:55 PST | |
5. | Device Fault Manager | 3.2.0 | 18 Feb 2010, 06:11:56 PST | |
6. | Health and Utilization Monitor | 1.2.0 | 18 Feb 2010, 06:11:59 PST | |
7. | Integration Utility | 1.9.0 | 18 Feb 2010, 06:11:58 PST | |
8. | Internetwork Performance Monitor | 4.2.0 | 18 Feb 2010, 06:11:57 PST | |
9. | LMS Portal | 1.2.0 | 18 Feb 2010, 06:11:58 PST | |
10. | Resource Manager Essentials | 4.3.0 | 18 Feb 2010, 06:11:58 PST |
09-01-2011 11:14 AM
From the server, open a command prompt and type: pdshow > c:\pdshow.txt. Attach it here please.
09-01-2011 11:22 AM
pdshow file is attached
09-01-2011 11:26 AM
Seems it did not get attached.
09-01-2011 11:30 AM
Is there a log or some other source to determine why it didn't start. I tried rebooting the server already.
09-01-2011 11:33 AM
Without knowing where the problem is, we cannot begin to understand what logs to check. First step is to look which processes are down (if any) and check corresponding logs. Hence, we need the pdshow.
09-01-2011 11:37 AM
09-01-2011 11:41 AM
OK, so here is the problem:
Process= RMEDbEngine
State = Never started
Please check this document and make sure you are complying with steps 1 and 2. If you have to change any services, then restarting after setting them correctly should fix this.
09-01-2011 12:39 PM
Restarting the server took care of the problem. net stop/start crmdmgtd wasn't enough
