10-12-2011 08:00 AM
Hello
I have many alarms with CWLMS 4.0. The alarms are OutOf Range Voltage, OutOfRange Temperature and OutOfRange Memory. For example:
I don´t know how eliminate this alarms for these equipaments. I am trying with Setting up the thresholds but nothing. Someone can help me?
10-14-2011 11:50 AM
The issue with Voltage sensors (and I suspect the others) is with the CWLMS product's polling incorrectly defining the expected range.
I had opened a TAC case for that very issue and Cisco engineering confirmed the problem. Bug CSCto53414 is open against this issue. (You can see it using Bug Toolkit.)
All you can do for now is acknowledge the (bogus) alarms.
Hope this helps.
10-14-2011 12:30 PM
Thanks mklemovitch for your response. It´s all extremely useful.
10-14-2011 09:15 PM
You're welcome. If you find the response helpful, please rate it.
